The cannon has three coil stages that accelerate the projectile one after the other. First, the coil is off and the projectile isn't moving. But then we turn on the coil, current starts to flow through the coil and the bullet starts to move because the magnetic field of the coil is accelerating it.
Here is a shot of the firing process in an oscilloscope. As you can see, current is first applied to the coil, then the CNY70 detects the projectile and the coil turns off.
- GATE = Gate of the MOSFET.
- IL = Voltage through the coil.
- A_IR = Analog output of the CNY70 sensor.
- D_IR = Digital output of the CNY70.
And this is the final result of the coil gun:
