As i said, i updated the interface of my machine. The result of a few hours of programming is now that you can programm a list of cables to cut. That means you can say: " yeah i want 2x 4cm and 5x 10cm ". Then you only habe to press the buttons and the machine does his job. :) This is a huge step in the possibilities you have with my project !! I hope you like it !! In a few days i will post the code :)
Kirschner Christoph
