The 2.0 board design is up on github
I'm working on 2.1 which has the following minor tweaks
- Input connectors moved to the 0.1" grid - this will make building an automated test jig easier.
- components moved over 0.1" to make room for
- locations added for thru-hole I2C pullups
- silk screen text adjustments (bigger fonts, moved around)
- full re-route
Suggestions on what color these should be? I'm bored with green, and purple is for OSHPark prototypes. Options are:
- green
- red
- yellow
- blue
- white
- black
- purple
- matt black
- matt green
Alastair Young
blue
