Ok so perhaps a better option would be to use a Linux box and use the Skype API to make the calls, accept them, etc. My only issue is I still may need a standalone hardware solution to handle the audio portion. The cost is similar as far as the cost to operate (magic jack vs. Skype) but it may offer benefits in cost save from not having to design and build the POTS interface.
Emach00
