Hacking the head
A project log for Portable Chaos Monkey
Information Radiator, Software Build Monitor
guy-winterbothamGuy Winterbotham 08/10/2014 at 23:250 Comments
This part was a PITA. Basic idea was in some way to attach a servo to some part of the mechanism that drove the movement of the lips. Unhacked, when you hit the monkeys head, it pushs down a rod that switches the direction of the motor and engages gears that:
I tried several different linkages but in the end just kept cutting linkages until I finally found enaging a rod was the easiest way.
This pic is not that great but shows the head disengaged.
By going for the rod I had to remove the linkage that moved the eyes. I made up for that by replacing them with LEDs that I could then control with the LCD panel.
That's how I roll. make it up as I go. More fun, more challenge. No frustration of a plan not working as there never was one.
