The new version is here ! HTTaP_src.20200504.tgz
I start to remove the s(n)printf calls that look like more trouble than they're worth. Convenience vs safety, right ? I still have to convert some places to the new system that gives me more control, and less sources of potential errors (or injections).
I also implement the new /?ping definition to help the client manage its own timers.
I still have the plans in sight, to demonstrate the "flexible" program (to dynamically switch from polled to blocking mode) but this required some tweaking here and there... At least now I have a new API to expose to the user, if/when there is a suitable #define : the default is below.
// define our own HTTaP parser :
#define HTTAP_PARSE my_HTTaP_parser
int my_HTTaP_parser(
char *request, // pointer to the request (receive buffer)
int recv_len, // byte count of the request
int ReqType, // 1 for GET, 2 for POST
char *b, // pointer to the send buffer
int *len) { // length of the send buffer
return 0;
You can now define your own keywords without touching the other files :-)
