• Bringup and FireWire
    Arya • 10/11/2019 at 00:20 • 0 comments
    Since there are no USB ports available, I can't exactly do a LiveUSB boot or something. Fortunately, I had an old SATA HDD with a Debian Jessie install on it, from an old server of mine. Long story short, that's how I booted this motherboard up.
    You also need network, don't you? I have a desktop computer with a free PCI slot and a PCI FireWire card. The card is good, but one of the SMD capacitors broke off... Let me fix that.
    You also need a cable. Fortunately, I bought one a couple of weeks ago, one like this:
    Connect my desktop and this laptop (both running Linux), load proper kernel modules, do some "ip addr" commands on both to set up static IPs, add routes (+disable an old firewall that was on the HDD install I reused):
  • Memtesting
    Arya • 10/10/2019 at 23:54 • 0 comments
    Don't need much RAM - there are two slots for DDR2, could put everything into RAM but likely won't for now. So, will just put some 512MB sticks in there, test them one-by-one. Found one:
    Good! Tested it for 8 more hours, works nice. Found one more:
    okay then. Next one?
