- Using a smaller LCD display gives better results due to the ligth could shine the entire image. It also allows to use a smaller magnify lenses and reduces the final size of the proyector.
- More power is always better, then i'm planning to upgrade the proyector with a 30W or 50W Led.
- Another useful upgrade could be add a condenser lens to the LED to harness the light in a more efficiency way.
- The AV compatibility is good and cheap to use with common entertainment systems. Now I wanna use the projector with a Raspi via Picast to play movies and content using my phone with internet access.
