400 x 600 - 60 watt Ten-High Chinese Laser Upgrade
How I upgraded my 60 watt laser from its crappy control system to something worth while.
  • 1 × SMAKN - TB6600 Stepper Driver 12-40V, 32 Microstep Driver, 4AMPs
  • 1 × Trocen - AWC708C Lite DSP Laser Controller, Ethernet, USB Host, USB Slave, Color LCD
  • 1 × Meanwell - NES-350-36 - 36V Power Supply UL Listed Power Supply 36v @ 9.7A
  • 1 × ASI - NDB1L-32C-10-120V - 10A GFCI Circuit Breaker GFCI Din Rail Mounted Circuit Breaker
  • 1 × uxcell - M4x15mm Self Clinching Threaded Studs Press in Sheet Metal Studs
View all 7 components
