Hackaday.io Hackaday.io
Sign up Log in
Ultra-duino Cleaner
We are going to build an ultrasonic cleaner using an Arduino as the brains and a few circuit components.
husain-shekhaniHusain Shekhani
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6.7k views
0 comments
32 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
6.7k
0
32
10
Team (1)
  • husain-shekhaniHusain Shekhani
Join this project's team
ongoing project
This project was created on 03/02/2017 and last updated 9 years ago.
Description
Drivers for ultrasonic cleaning piezoelectric transducers cost >$150. Can we make one with an arduino and a few simple circuit components?
Project Logs
Collapse
  • Part E - Programming PicoScope & Python for Characterization
    Husain Shekhani • 05/09/2017 at 16:31 • 1 comment
  • Part D: Capacitance measurement
    Husain Shekhani • 04/05/2017 at 17:07 • 0 comments
    In this project log, we are going to measure the capacitance of the ultrasonic transducer using both AC excitation and also DC methods (time constant).
    More fun with USB oscilloscopes!
  • Part C: Resonance Frequency by Mechanical Impluse
    Husain Shekhani • 04/03/2017 at 22:15 • 0 comments
    In this project log, we will show how to determine the resonance frequency of the transducer using a mechanical impulse, namely, hitting it with a marker.
  • Part B: Resonance Frequency by Excitation
    Husain Shekhani • 04/03/2017 at 22:13 • 0 comments
    In this project update, we use a USB oscilloscope, a resistor, and voltage probe to determine the resonance frequency of the ultrasonic cleaning transducer using excitation. The resonance frequency occurs at the largest current frequency.
  • Part A: Introduction to DIY Ultrasonic Cleaner
    Husain Shekhani • 03/28/2017 at 21:56 • 0 comments
    In this video, I describe the project in general.
    We are going to need:
    1. Signal source
    2. Amplification
    3. Drive transducer
    4. Bond transducer to container
    Yes, there will be a lot of details to come. Best of all (maybe), we will use an Arduino to drive the cleaner, hopefully.
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
I built and tested, using an oscilloscope, a passive crossover. I will use this crossover for my DIY speakers.
Project Owner Contributor
Crossover design
anna-gellAnna Güell
We have a cost-effective capacitance meter to measure capacitance using Arduino.
Arduino Capacitance Meter
hiotronhIOTron
315Mhz jammer with Menu
315MHz Jammer with Arduino and fs1000a
cifertechCiferTech
Kinetic flowers that really move
Hothouse
alex-leitchAlex Leitch
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Ultra-duino Cleaner", please tell us the reason.
Send message
Remove Member
