Short video and PCB prototype
A project log for RGB seven-segment display [RSSD]
My journey to create a big but thin, evenly illuminated seven-segment display.
janJan • 03/23/2017 at 17:22•0 Comments
I've been on a short trip, so I had little time for my project. Anyway I've created a prototype PCB (through-hole components will be substituted with SMD parts soon):
I'll use two LEDs for each segment to keep the overall thickness to less than 15mm. I added a short video in the files section which shows one segment lit with two different colors.
I think very cool effects will be possible with this configuration. The PCB will get an Atmega328, ISCP etc for programming so the unit can be used on its own.
