I was laidoff this summer and had a lot of parts laying around from an old reprap kit and decided a laser engraver could easily be built once I found a laser module.
The build was paused when my wife and I got a puppy and then I got a new job.
I have finally been able to put some work into it recently.
Over the weekend I was able to finish the box up. I got the lid panels cut and attached with the window installed. I cut out the holes and installed the kill switch, exhaust fan, and power input. I also picked up a 24" x 24" piece of aluminum to use as the bed so hopefully no fires will be started.
This week I hope to finish the wiring and start testing.
