These photos are of another unit found recently on ebay. [Photos used with permission]
If you decide to purchase this unit, please keep in touch, and consider joining the 'team' here to contribute!
This unit differs from mine in at least one notable way; mine doesn't say anywhere on it that it's a Kaypro 2x. @ziggurat29 had to figure this out by looking up Kaypro motherboards!
[Also, an odd note, apparently when using 'cpmtools', one must select 'kpiv', even though the Kaypro IV is an entirely different beast(?)]
[TODO: take similar shots of mine for side-by-side.]
This appears to have the drop-down door type latch floppy drives, whereas mine has the rotating lever-latch.
"Kaypro 2x" heh, that'd've been handy
Hmmm, my pods are merely heatshrunk, and their cables merely ribbon cables. [And, crosstalk/interference was an issue]. Seems even more plausible, now, mine might've been a prototype?
A carrying case!
Eric Hertz
