Use IMD117 (118 doesn't extract properly)
Settings, Attempt 1:
Cyl: 40
Double-Step: Disabled
(Presumably: Since a 1.44MB drive can work with 720KB floppies in an IBM/PC configured for a 360K drive: the 720KB "notch" indicates to the drive to double-step. I'm using a 1.44MB disk, with the notch covered)
---- Write Disk From File ----
LOTS of notes in disk image... too many to see on-screen.
(Isn't there a viewer utility that came with imagedisk????)
"Written with R/W Gap=20, Format Gap=23"
ImageDisk reports, while writing:
"A: 250k DD" (250kbps?)
"G1:7" "G2:14" (???)
"21/1: Write error <19> NoData" ???
"33/0: Write error <8> NoData" ???
"800 sectors (100 Compressed)
Write complete..."
The scrollbar at the top shows only half the disk written (?)
Did the drive not double-step automatically? Or...?
Also... I thought 360K drives were 300kbps, but then they wouldn't be interchangeable...?
Note that I used "Calculated" for gaps rather than entering the aforementioned values.
Disk wrote, despite odd gap-lengths necessary for fitting 10 sectors... so... maybe a go.
Time to throw the 3.5in drive in the KayPro.
Oh, obviously managed to get the 486 laptop's floppy drive working... Tried another belt. This one smaller (both require quite a bit of stretching) in diameter, but thicker material. Stretch was harder... Thought: The other might've been too stretchy while spinning? Who knows.
Odd effects using disks made in linux under win95... "mkfs.vfat -I /dev/sdb" may have some issues... as formatting under windows (DOS) then using on the linux machine seems to be fine. Odd effects include: disks showing less available space than they should, files written to disk appearing *very* strange when 'dir'ed... including one 'directory entry' which appeared to be the contents of a file? Oddly, these disks work fine under linux.
