IMU driven head mechanism prototype
A project log for Droidbot 07 - Wheeled-Quadruped
An ambitious mobile robot for testing my skills and learning new ones.
paul-crouchPaul Crouch 10/03/2017 at 18:470 Comments
I’ve got some crude code working; reading a MPU6050 IMU then mapping the pitch and roll values to the servos outputs. Obviously, as there's two opposing servos per axis, one has to turn clockwise and the other counterclockwise in order move the platform. I will need to re-work the mechanism for the actual robot and smooth the code but I'm happy the concept works.
