It is a basic design of wooden frame,fixed with two-way mirror.To hold the monitor in place,I have drilled 4 holes on two sides of this frame.I could have made this design more compact ,but due to reason that I do not have separate parts particularly for this project like computer monitor,camera etc.
There is enough space in the frame to hold other hardware like raspberry pi, camera ,speaker,dc adapter,relay,PIR sensors,wires etc.
The PIR sensor will be installed on the sides of the frame by drilling holes on each side.These sensors are used to control features like music stream,lights controls etc.
This design was made so as to disassemble and reuse the hardware when necessary.Else can be more compact.
shubham khatri
