Version 1 conclusion
A project log for Electric roof brush v1 [FAIL]
I need to clean my roof so why not creating a usefull tool.
f4drjf4drj 11/25/2024 at 10:320 Comments
I thought motor was powerfull enough but unfortunatelly not.
Tests was done on smooth floor and on real tiles which was significantly worth.
When scrashing a little bit a surface, friction is much higher than the motor can reach.
Design is good but mecanic is not.
Second version of this roof cleaner will contain two brushless motor and Herringbone gears.
More improvement will also be no remote wiring and "power back pack". Battery will be hosted directly inside the brush.
