Good news it's seems that the 445nm laser can also cure this, but using only 2x 385nm LED isn't enough, the 415nm laser is much faster, have to make a heat sink for the last.
Keep bottle upright.
A project log for CNC Add-on: Rot. Laser Soldering Paste applicator
Using a cheap tire compressor, driven by a stepper motor, to apply solder paste from a syringe and then soldering small wires to components.
