The case
The next part of the process is to design and build the case.
The case is composed of 4 plates :
- the « base » plate where switches will be mounted,
- the « supporting » plate,
- the « spacer » plate,
- the bottom plate.
In picture :
_
__|_|__
| | 1.5mm « base » plate
| \_______/ | 5mm « supporting » plate
| | | | 5mm « spacer » plate
| | 5mm « bottom » plate
The goal is to design 4 SVG files that will feed a laser cutter.
Since I’m not familiar at all with that process, I'm thinking to first design a 3 keys keyboard (volume up, down and mute).
That will limit the costs if things goes wrong.
