Do you need a device that can install a bootloader on your classic arduino that has been corrupted or has just undergone surgey?
Do you need to back up a favourite project you have lost the code for?
Do you need to flash many ics without the need for a computer?
Here i present the Ardubytes AVR Programmer.
Features (Options In Interface):
1. Restore Firmware To Standard Boards. E.g Arduino Uno, Nano (16/8MHz), Leonardo and Mega.
2. Flash Your Own Firmware. All You Need Is A Hex File & Fuse File.
3. Backup Your Project. Hex File and Fuses File Saved To A Micro SD Card.
4. Flash Eraser. Fuses Remain Unchanged.
5. View Fuses.
6. Up to 255 Folders To Store Your Projects.
7. Timeout Alert To Give The User A Indication if something has gone wrong.
To Be Tested ...
1. A Method To Load Other AVRs That Are Not Currently Supported. So System Can Support Other AVR's.
