Durian Leaf Moisture
Smart Management of a Durian Orchard
Public Chat
0 followers
Durian, as a significant tropical cash crop, is beloved by consumers worldwide for its unique flavor. However, durian trees are highly demanding when it comes to their growing environment, with leaf temperature and humidity playing a critical role in their growth and fruit yield.
Durian trees thrive at an average annual temperature of 22°C to 30°C.
Durian trees have high water demands, requiring an annual rainfall of at least 2,000 mm.
By monitoring the temperature and humidity of the leaves over a long period to determine the growth condition of the plant。
Innovative Monitoring Solution: FDR-Based Leaf Moisture Monitoring
To gain deeper insights into the growth conditions of durian trees, we introduced an Frequency Domain Reflectometry (FDR)-based solution for monitoring leaf moisture and temperature.
Working Principle
The FDR sensor detects changes in the dielectric constant caused by liquid on the leaf surface, providing precise measurements of leaf moisture
  • Working Principle The FDR sensor detects changes in the dielectric constant caused by liquid on the leaf surface, providing precise measurements of leaf moisture content.
  • Device Design The sensor probe is shaped like a leaf to more realistically simulate the physical properties and thermodynamic behavior of natural leaves, ensuring more reliable monitoring data.
  • The communication mode of LoRaWAN.
    Makerfabs12/10/2024 at 02:37 0 comments
    Due to the remote location of the durian orchard, which is far from residential areas, the availability of WiFi signals is limited. Given the advantages of LoRaWAN, such as its long-range transmission, low power consumption, and robustness in challenging environments, we have opted for LoRaWAN as our communication solution. This choice ensures reliable connectivity for our orchard's operational needs without the constraints of traditional WiFi coverage.
View project log
