Aside from Microchip apparently deciding to rename all the peripheral registers, going from "running" to "blinking the LED" went pretty quickly. Running at 48MHz, 2 wait states, and outputting the clock on its respective IO pin. Woo hoo!
int main(void) {
// Clock at reset is set to the internal 48MHz clock, divided by 12.
NVMCTRL_REGS->NVMCTRL_CTRLB |= NVMCTRL_CTRLB_RWS(2); // 2 wait states for 48MHz
OSCCTRL_REGS->OSCCTRL_OSC48MDIV = 0; // no division
GCLK_REGS->GCLK_GENCTRL[0] |= GCLK_GENCTRL_OE_Msk; // output the clock on a pin
PORT_REGS->GROUP[0].PORT_DIRSET = GCLK0_OUT;
PORT_REGS->GROUP[0].PORT_PMUX[GCLK0_PIN/2] |= 7; // PMUX H is clkO
PORT_REGS->GROUP[0].PORT_PINCFG[GCLK0_PIN] |= PORT_PINCFG_PMUXEN_Msk;
PORT_REGS->GROUP[0].PORT_DIRSET = LED;
while (1) {
PORT_REGS->GROUP[0].PORT_OUTTGL = LED;
mydelay();
return;
