The final device should be usable by medical students for actual training, or even by physicians with no access to high-end ultrasonography equipment. Usage of the device should therefore require no technical knowledge outside what is expected of them.
At least 32 - 64 piezoelectric elements are required for reasonable resolution, as well as dedicated electronics and a powerful FPGA for digital signal processing. The most common range of frequencies in abdominal ultrasound should be handled, and phased array beam steering and focusing would improve the quality of images. Tissue harmonic imaging and color-coded Doppler imaging could additionally be provided.
The device should be easily manufactured by resorting to commonly available techniques and services, as well as open-source software and open standards. Ideally, interaction with it will be done via a connected consumer device, reducing the number of pieces to purchase and assemble. Everything should be kept to a manageable cost.
Aritz Erkiaga
brian bloom
Scott Hasse
