- 1-56KiB of RAM with software configurable mapping and size.
- SD card storage with transparent LOAD/SAVE integration.
- Embedded support commands in an overlay ROM for instant availability.
- Supports pseudo high resolution graphics.
- Supports true high resolution graphics, WRX.
- Supports user defined characters, CHR$64 or CHR$128.
- Dual emulated AY-3-8910 or YM2149 sound chips, model selectable.
- Sampled stereo audio output.
- Joystick connector, standard 9-pin ATARI compatible. Several modes of direct reading. Also sends data via keyboard injection.
- Serial IO via extension connector.
- ROM selectable: ZX80, ZX80 ZXpand, ZX81, ZXpand+ or Big Bang X2.
- A button to control soft, hard or factory reset.
- A button to enter the config menu.
- Configuration options via ZX81 keyboard & screen.
- Composite video output with backporch.
- Battery backed real-time clock with time and date.
- Firmware update via USB.
- Open source hardware and software!
Hi,
I'm building the OpenXPand version, but I can't find the SD card slot. Do you have any idea where it is? Thanks
