We got to a problem today that the supporting component between the maze and the board perpendicular to the bottom is not that suitable to get the cube fixed. We put 3 supporting components on the maze board.
In the maze, we made 2 start points and 6 destination points so that 12 pathways of Simon says game are available. We drew a blueprint of the maze and designed the pathways. After that,
We finally attached each button on the assigned point on the maze board to be pressed when a player complete the instructions given by the screen to get to a destination point.
