charkster has been really awesome to port this code over to work with Raspberry Pi and MicroPython.
As cherry on top, he as also add in a web interface for ESP32-C3 so you can control RotoPD over the wifi!
Check out his GitHub!
A project log for RotoPD - USB-C PD 3.1 Breakout I2C
Advance Power Delivery trigger that is designed up to 30V. All the power that you have ever need from USB-C! Also AP33772S Evaluation Board.
