As mentioned, I had two incomplete keyboards. Each was mostly complete with a couple keys/switches broken. Intentionally I had bought two with complimentary keys missing. So, I selected the PCB with the cleanest switches to be the base for the build. I only had to swap three switched. The big through hole parts and my Hakko FR-301 desoldering tool made the work simple.
After that, I simply covered the back of the PCB with some electrical tape to minimize the chance of shorting something out since the PI was going to be located below the PCB.
John Anderson
