3. Investigating
A project log for LG Smart Power Plug MTTL-W01
Control the power plug from a simple web server
mwahidmwahid 12/25/2024 at 11:470 Comments
After identifying as many components as I could, it is time see how things work. So, I got my $10 logic analyzer and $20 FT4232-56Q module out and got to work.
I connected the three I2C buses to the logic analyzer and the two UART ports to the FT4232 module, then turned on the device. I turned ON/OFF some relays while recording everything, and below are the logs.
UART_LOG
I2C1 & I2C2
Current measurements I2C frames
LED-I2C
Relays I2C control
Relays I2C control
WiFi
Firmware
