Gesture and Voice-Controlled Home Automation System
Introduction
Welcome to a project that redefines the way the defines the way we interact with home automation Using the power of DFRobot Gravity GR10-30 Gesture Sensor and DFRobot Gravity Offline Language Learning Voice Recognition Sensor, this system offers an intuitive and futuristic way to control appliances. This project combines two cutting-edge technologies from DFRobot a trusted name in the open source hardware community.
What Makes This Project Unique?
This isn't your regular home automation project. it's powered by advanced DFRobot Gravity GR10-30 Gesture Sensor with 12 distinct gestures and DFRobot Gravity Offline Language Learning Voice Recognition Sensor all offline, it's privacy-focused, fast, and reliable-perfect for smart homes of the future.
Story Behind the Project
The idea for this project was born from a desire to create something truly futuristic-a system that feels like it's straight out of a sci-fi movie. Imagine walking into the a room, swiping your hands to control lights, or saying a command to turn on appliances, all without touching a switch!
Challenges and Learning
Building this wasn't easy. Integrating multiple sensors, ensuring the real-time responsiveness, and achieving seamless operations, prototyping, and countless hours of coding. However, the journey was worth it, resulting in a project that's not only functional but also truly innovative. The DFRobot sensors played a significant role in simplifying this process. Their ability to switch seamlessly between I2C and UART communication made with integration much easier and more efficient.
DFRobot: Providing This Innovation
About DFRobot
DFRobot is a leading innovator in open source hardware, offering a wide range of high quality sensors, controllers, and modules. Their products are known for their user friendliness, reliability and comprehensive documentation, making them a favorite among the developers and hobbyists alike
Gravity Series:
The Gravity series is DFRobot's flagship line of of plug-and-play modules, designed for ease of use. These modules come with Product Wiki, Extensive Compatibility and Robust Design
Boson Series:
The Boson Series by DFRobot is a modular, plug and play system of over 50 electronic building blocks designed for creators, educators, and hobbyists. It simplifies prototyping with color-coded, solder free modules like sensors, actuators, and logic controls. It is Ideal for STEAM education and DIY Projects. its user friendly design, robust safety features, and detailed wikis make it perfect for beginners and professional alike, enabling quick and hassle free project development.
Components Used in This Project
1. Gravity: GR10-30 Gesture Sensor
2. Gravity: Voice Recognition Module
3. Arduino Mega 2560
4. 4-Channel Relay Module
5. Connecting Cables & Power Supply
Features of the Project
Gesture Control:
Voice Recognition:
Setting Custom Wake ID
1. Use the default wake-up word to activate the assistant.
2. Say the phrase: "Learning wake word" to begin.
3. Follow the prompts:
4. You can now use this wake-up word to activate the assistant.
S.noWake-up Words ID
1Wake-up words for learning 1
2Hello Robot 2
Setting Custom Command IDs
1. Activate the assistant using the wake-up word (default or customized).
2. Say: "Learning command word" to initiate the process.
4. After completing the process, a unique ID will be assigned to each learned command.
Deleting Wake and Command Words
1. Activate the assistant with the wake-up word.2. Say "I want to delete" and follow the prompts to:
Using the Command IDs
By following these steps you can fully customize the voice assistant to meet your specific needs and enhance your project's functionality. For more Information Check this Out ProductWiKi
Connections
Wiring Diagram:
Gesture SensorArduino Mega 2560
SDASDA
SCLSCL
GNDGND
VCCVCC
Voice RecognitionArduino Mega 2560
RX18 TX
TX19 RX
GNDGND
VCCVCC
4 CHANNEL RELAYARDUINO MEGA 2560
IN 12
IN 23
IN 34
IN 4 5
VCCVCC
GNDGND
Code
Required Libraries:
Download the libraries from the above links before uploading the code
#include "DFRobot_GR10_30.h"
#include "DFRobot_DF2301Q.h"
#if defined(ARDUINO_AVR_UNO) || defined(ESP8266)
#include <SoftwareSerial.h>
#endif
const int relayPins[] = {2, 3, 4, 5}; // Relay pins for relays 1, 2, 3, and 4
int relayStates[] = {0, 0, 0, 0};     // Array to track states of all relays (0 = OFF, 1 = ON)
// Gesture Sensor Initialization
#if defined(ARDUINO_AVR_UNO)||defined(ESP8266)
SoftwareSerial softSerialGesture(/*rx =*/4, /*tx =*/5);
DFRobot_GR10_30 gr10_30(/*addr = */GR10_30_DEVICE_ADDR, /*pWire = */&Wire);
#else
#endif
// Voice Recognition Module Initialization
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266))
SoftwareSerial softSerialVoice(/*rx =*/6, /*tx =*/7);
DFRobot_DF2301Q_UART asr(/*softSerial =*/&softSerialVoice);
#elif defined(ESP32)
DFRobot_DF2301Q_UART asr(/*hardSerial =*/&Serial1, /*rx =*/D3, /*tx =*/D2);
#else
DFRobot_DF2301Q_UART asr(/*hardSerial =*/&Serial1);
#endif
int S = 1; // Variable for relay selection, initial value 1
int W = 0; // Variable for ON/OFF control, initial value 0
void setup() {
Serial.begin(115200);
for (int i = 0; i < 4; i++) {
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], HIGH); // Turn all relays off initially (default state)
while (gr10_30.begin() != 0) {
Serial.println("Gesture Sensor initialize failed!!");
delay(1000);
Serial.println("Gesture Sensor initialize success!!");
gr10_30.enGestures(GESTURE_UP | GESTURE_DOWN | GESTURE_LEFT | GESTURE_RIGHT);
while (!(asr.begin())) {
Serial.println("Voice Recognition Module initialize failed!!");
delay(3000);
Serial.println("Voice Recognition Module initialize success!!");
asr.settingCMD(DF2301Q_UART_MSG_CMD_SET_MUTE, 0);
asr.settingCMD(DF2301Q_UART_MSG_CMD_SET_VOLUME, 7); // Set volume to 7
asr.settingCMD(DF2301Q_UART_MSG_CMD_SET_WAKE_TIME, 20);
void loop() {
// Gesture Handling
if (gr10_30.getDataReady()) {
uint16_t gestures = gr10_30.getGesturesState();
if (gestures & GESTURE_RIGHT) {
S++;
if (S > 4) S = 1; // Reset S to 1 if it exceeds 4
Serial.print("Relay selected: ");
Serial.println(S);
if (gestures & GESTURE_LEFT) {
S--;
if (S < 1) S = 4; // Reset S to 4 if it goes below 1
Serial.println(S);
if (gestures & GESTURE_UP) {
W = 1; // Turn ON the relay corresponding to S
relayStates[S - 1] = 1;
Serial.print("Relay ");
Serial.print(S);
Serial.println(" ON");
if (gestures & GESTURE_DOWN) {
W = 0; // Turn OFF the relay corresponding to S
relayStates[S - 1] = 0;
Serial.print(S);
Serial.println(" OFF");
// Update the states of all relays
digitalWrite(relayPins[i], relayStates[i] ? LOW : HIGH);
// Voice Recognition Handling
uint8_t CMDID = asr.getCMDID();
switch (CMDID) {
case 5:
relayStates[0] = 1;
Serial.println("Relay 1 ON");
Serial.println(CMDID);
break;
case 6:
relayStates[0] = 0;
Serial.println("Relay 1 OFF");
break;
case 7:
relayStates[1] = 1;
Serial.println("Relay 2 ON");
break;
case 8:
relayStates[1] = 0;
Serial.println("Relay 2 OFF");
break;
case 9:
relayStates[2] = 1;
Serial.println("Relay 3 ON");
break;
case 10:
relayStates[2] = 0;
// Serial.println("Relay 3 OFF");
break;
case 11:
relayStates[3] = 1;
Serial.println("Relay 4 ON");
break;
case 12:
relayStates[3] = 0;
Serial.println("Relay 4 OFF");
break;
default:
if (CMDID != 0) {
Serial.print("Unknown CMDID: ");
// Update relay states for voice commands
delay(300);
Demonstration
Check out this project in action ! Watch the video below to see how gestures and voice commands control the relays effortlessly
Conclusion
This home automation system system is a perfect blend of innovation and practically. It showcases the immense potential of DFRobot's Gravity series while setting a new bench for what smart home systems can achieve.
If you've never seen such a project before, now's the time to dive into the future of home automation
