Converted this 125 volt lamp to a Portable lamp that can be plugged in or used with a battery bank. Built custom led Bulbs to fit inside the original wiring and yes it was already quite broken when I found are the Thrift store. So it Didn't really slaughter a Vintage collectable kiddies. I also fixed it with epoxy and planning on painting it and sculpt it a bit more to fit the keeper more wrinkles the better and add more to this One of a kind Diorama.
