I added a debugging function because it was getting crazy to debug when something went wrong. Parsing directly from a string takes a lot of steps. Now if I have debugging on, if there is an error I can see exactly what went wrong (sorta).
I added the "L" and "LG" builtin KEYWORDS for LOOP and LOOP_GROUP. Here is how they work:
0K 100 : <O 0K> L @ <0K 100 : O 0K> LG
The code enclosed with "< >" will be looped.
"L" will scroll the program counter until it reaches a SEPERATOR ":" symbol.
"LG" will scroll the program counter back until it reaches a GROUP "@" symbol, this allows for repeating a GROUP as many times as wanted. All KEYWORDS being global, effectively this can be very useful.
it's pretty simple and works as intended.
I also have assigning a value of a KEYWORD to another keyword setup:
12K 2K
The above sets the value of 12K to the value of 2K. I need to work on parsing math operators next. In the original GORK, my plan for the rules of math operators to be as such:
- A string KEYWORD or literal can only be added to or have something added to it, e.g. concatenation
- If a string of keywords and literals are added together, and there is a string in there, the final result will be a string. If there is no string, if there are no floats, it will be an integer, otherwise it will be a float.
- Adding 1 to keyword 1K looks like this "1K + 1", there is no need for ++ or += or "1K = 1K+1" like in C or Python. The goal is to reduce as many characters needed to write a program.
4K 12 - 2 + $ Day's until January $ + 12 + $th$ [VALID: 4K = $10 Day's until January 12th$ ) ] 2K 128 2K + 4 / 12 - 16 * 1.234 [VALID: 2K = 108.589] [INVALID OPERATIONS] 4K $Howdy$ - 10
