I stayed up late last night working on the interpreter. I made a lot of really good progress. But this is real life and often times there is good news and bad news.
I moved the entire interpreter into a class. I am not sure why I didnt start it out this way, but I realized it was inevitable and the longer I went without doing it the more tedious it would be.
I spent a lot of time working on error handling, and was able to impliment and catch syntax errors that would before freeze the interpreter.
I then decided to make the first port of the PC developement interpreter to the Pico Picow. This was also going great. It was exciting to finally be able to write commands on the devices console. I added a larger command history on the device, from it remembering the last command to remembering the last 8.
And then as I was testing it on the Pico device, I went to save it again and somehow overwrite the last several hours of work. I know I was tired but this was unacceptable. I need to use a better version control than just saving multiple copies at random times. I did not lose all my work, just from wherenI started porting it to the device.
So, these features I speak of exist, but I will have to re write them. Once I get back to where I was with the code, I will make a video as that was a good level of functionality to demonstrate the device.
Gordon
