I don't plan to go to Japan, but if I did, I'd still like to connect to MINIBOT with my phone and see what's going on under my couch.
I already use Tailscale, so I will install Tailscale on the raspberry pi in order to access it from anywhere. I set up a second wifi router with a different subnet than my main router. The pi is connected to internet through wifi, and to the second router by ethernet. Now I can have MINIBOT and whatever other wifi sensors I want to talk to the Pi able to do so but not take up traffic on main router or be exposed to the main LAN.
(WWW)---(home router) | wifi | <TailScale> [Raspberry Pi] | eth | (router2) / | \ / | \ wifi wifi wifi / | \ [minibot] | \ ( OO( )( ) [?] [?]
