Open source hardware standard and specification for synthesizer modules in a simple affordable metric form-factor!
- 180mm Tall
- Modules are multiples of 20mm or 10mm wide
- Electrically compatible with EuroRack
- Adapter plates for compatibility with EuroRack
- Same power standard as EuroRack
- Cases made from 2020 Aluminum as rail
- 3D printable cases
- M4 Metric Screws and 2020 T-Nuts
All made from common parts in the open source ecosystem, round number metric dimensions of modules, interoperability and compatibility with existing paradigms.
