Hackaday.io Hackaday.io
Sign up Log in
width and motion sensor
bdwidth sensor is a high resolution optical width and motion sensor for 3D printer.
markmark
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.1k views
0 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.1k
0
11
10
Team (1)
  • markmark
Join this project's team
ongoing project
This project was created on 01/02/2025 and last updated 8 months ago.
Description
We have developed a unique algorithm that can automatically compensates for the filament shadow on the CCD sensor even if the filament moves at different heights and angles.
Flow rate adjust: adjust the flow rate in real time
Jam/Runout: Pause the printer while jam or runout (laser motion sensor chip)
Width Accuracy: +/- 0.015mm (high resolution 0.005mm ccd sensor chip)
Connection: USB or I2C
It works right out of the box.
No mechanical contact with the filament, no wear due to the use of optical components
Just power it, then you can measure your filament motion&diameter.
more details: https://github.com/markniu/bdwidth
Project Logs
Collapse
  • support multi BDwidth sensor work at the printer
    mark • 09/12/2025 at 23:15 • 0 comments
    For example:
    [bdwidth fila_width_0]
    port:usb
    [bdwidth fila_width_1]
    port:usb
    [bdwidth fila_width_2]
    port:usb
    For example:
    the section of the sensor should like this:
    port:usb
    port:usb
    port:usb
  • Ardunio code
    mark • 08/13/2025 at 01:48 • 0 comments
    for someone wants the Arduino test code to communicate with bdwidth sensor https://github.com/.../main/arduino/mega328p_bdwidth.ino
  • auto flow printing test
    mark • 06/09/2025 at 07:15 • 0 comments
    While doing this printing test, I found a significant difference between enabling and disabling the width sensor. The same G-code file was printed on the same printer within half an hour.
  • Auto turn on/off the screen
    mark • 05/21/2025 at 05:40 • 0 comments
    It uses the motion sensor to determine whether to turn the OLED on or off.
    • Off: The OLED will be turned off if no filament motion is detected within 10 minutes.
    • On: The OLED will be turned on immediately if motion is detected.
  • How about your 3D filament?
    mark • 01/17/2025 at 01:59 • 0 comments
    It is hard to find out this 1.9mm diameter problem in this short range of 1Kg filament until the bdwidth sensor find it and pause the printing.
  • Why a width sensor is needed
    mark • 01/09/2025 at 03:39 • 0 comments
  • accuracy test
    mark • 01/03/2025 at 02:31 • 0 comments
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
I also want to make a 6DOF mouse
Project Owner Contributor
One more 3D mouse
vedranVedran
Checking out how carbon monoxide detectors work in a controlled environment
Testing Carbon Monoxide Detectors
adam-fabioAdam Fabio
Alternatives controler to play a racing car game
VVVroummm
romainbouvetromain.bouvet
Reverse Engineering of Artillery Sidewinder x2 Bltouch auto bed leveling sensor Electronics PCBA and Mechanical
Artillery X2 Bltouch Reverse Engineering
electronxElectronx
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "width and motion sensor", please tell us the reason.
Send message
Remove Member
