bdwidth sensor is a high resolution optical width and motion sensor for 3D printer.
For example:
[bdwidth fila_width_0]
port:usb
[bdwidth fila_width_1]
port:usb
[bdwidth fila_width_2]
port:usb
For example:
the section of the sensor should like this:
port:usb
port:usb
port:usb
for someone wants the Arduino test code to communicate with bdwidth sensor https://github.com/.../main/arduino/mega328p_bdwidth.ino
While doing this printing test, I found a significant difference between enabling and disabling the width sensor. The same G-code file was printed on the same printer within half an hour.
It uses the motion sensor to determine whether to turn the OLED on or off.
It is hard to find out this 1.9mm diameter problem in this short range of 1Kg filament until the bdwidth sensor find it and pause the printing.
