Pico Drum Machine
Pico 2 powered drum machine that plays notes stored in SD card through the DFMiniPlayer.
Greetings everyone and welcome back. Here's something loud.
The Pico Drum Machine is a DIY drum machine powered by the Raspberry Pi Pico 2 combined with the DF Mini player and a custom button board.
We wanted to test out an experimental setup that consists of a PICO paired with a DFMini player and a button board. Audio files on the SD card of DFplayer will be played when any button is pressed. Each button corresponds to each audio file. Here, the drum machine was to be controlled via this logic.
To test this idea out, we developed a simple 8-button breakout board in which all buttons are linked to GND and have 8 separate pinouts for each button; all buttons will be connected to Pico in the INPUT_PULLUP configuration.
In terms of sound, we downloaded the Audio Notes or recordings of Drum Kit instruments such as the bass drum, cymbals (Crash, Ride, Splash), snare drum, and tom-toms.
This article is about the whole build process of this project so let's get started with the build.
Drum Machine Button Circuit
We started this project by creating a schematic for the button board, which consists of eight push buttons. Each button's NC terminal is linked to GND; all eight buttons NO Terminals are connected in a sequential manner to the terminals of the CON9 header pin, as well as the ground port. This header pin will be used to mount the button board on a breadboard and interface it with the Pico 2.
Using Fusion360, we generated a basic model with all of the switches allocated to their respective positions, as well as four mounting holes in case this board needs to be attached to a body.
We built the board file based on the Cad file dimensions and positioned the switch exactly where it should be.
We complete the board by joining all the traces and creating the gerber data for the PCB.
Seeed Studio Fusion
Following the completion of the Gerber data, we uploaded the file to Seeed Fusion's website and placed an order for a yellow Solder mask with white silkscreen.
PCBs were received in a week, and their quality was super good considering the rate, which was also pretty low.
Seeed Fusion PCB Service offers one-stop prototyping for PCB manufacture and PCB assembly, and as a result, they produce superior-quality PCBs and fast turnkey PCBAs within 7 working days.
Seeed Studio Fusion PCB Assembly Service takes care of the entire fabrication process, from Seeed Studio Fusion Agile manufacturing and hardware customization to parts sourcing, assembly, and testing services, so you can be sure that they are getting a quality product.
After gauging market interest and verifying a working prototype, Seeed Propagate Service can help you bring the product to market with professional guidance and a strong network of connections.
DRUM.rar
x-compressed - 334.80 kB - 01/02/2025 at 10:19
Download
DRUMSCH.pdf
Adobe Portable Document Format - 100.13 kB - 01/02/2025 at 10:19
Preview
  • 1
    Drum Machine Button Circuit Assembly
    • We begin the button circuit-built procedure by positioning all of the buttons on the top side of the board.
    • Next, we turn the board over and solder all of the button pads with a soldering iron.
    • We then placed the CON9 header pin from the bottom side of the board and soldered its pads from the top side.
    The button circuit assembly process has been completed.
  • 2
    Brain and Brawn of this project: Raspberry Pi Pico 2 and DFMini Player Module
    We select to utilize the Raspberry Pi PICO 2 as the brain of this project, along with the DFmini player as the brawn.
    The primary controlling part is done by the NEW RASPBERRY PI PICO 2, which is the upgraded and powerful microcontroller board centered upon the RP2350 microcontroller, the new Dual Arm Cortex-M33 or dual RISC-V Hazard3 cores running at 150 MHz and 520 KB on-chip SRAM and 4 MB on-board QSPI flash.
    The DFmini Player is a mini MP3 Player Module that is based around a 24-bit DAC IC along with an onboard SD Card reader that fully supports the FAT16 and FAT32 file systems.
    This module supports a variety of control modes, including I/O control mode, serial mode, AD button control mode, etc., meaning the user can use this board as a standalone device or use an external microcontroller to drive the module.
    For more info about this module, you can checkout its product wiki published by DFROBOT.
    https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299
  • 3
    Wiring Diagram
    • Let's start the wiring process of this project, which was quite straightforward. We first connect the GND of PICO2, DFmini player, and Switch board together.
    • Next, we connected the VCC of the DFmini player with PICO's VBUS terminal.
    • The first switch connected to GPIO14, the second to GPIO15, the third to GPIO16, the fourth to GPIO17, the fifth to GPIO18, the sixth to GPIO19, the seventh to GPIO20, and the eighth to GPIO21.
    • The speaker is connected to the DF player's Speaker 1 and 2 pins.
View all 6 instructions
