Gold Prospecting Shovel
Find gold with the NuggetGrabber Shovel
There are plenty of tools and gadgets for prospecting, but the most fundamental of them all have most often been neglected... The Shovel.
Recently I set out on a mission to perfect the regular spade and design a prospecting shovel that is collapsible to make it easier to bring on your expeditions, but also with a better shape to hold more material without loosing any of your precious gold.
The first prototype has just been built and this spring I intend to run a crowdfunding campaign on Kickstarter to bring the little gadget to market. Join me on this great adventure!
As an amateur goldpanner and prospector I have travelled to a handful of places all around Europe on the hunt for shiny specks of gold. With gold prices soaring it's a hobby increasing in popularity, and gold can be found almost anywhere in the world. Some gold miners even find nuggets worth thousands of dollars!
When panning for gold, you use a shovel or spade to get material from the creek or surrounding areas to put in a classifier or a goldpan. Regular shovels are often big and flat, letting most of the material run off the shovel and loosing precious gold. The shovel I am designing has a special siding and riffles to prevent any gold-bearing material to slip away.
Gold prospecting often occurs deep in the wilderness unaccessible by car. That is why the shovel also will have a collapsible handle from glass fiber-reinforced polymer, for easy transport and storage.
Read more on my website: nuggetgrabber.com
  • Working on the first prototype
    Daniel Nikolajsen2 days ago 0 comments
    Nothing beats the feeling when you go from idea to an actual prototype. After extensive research and ideation, it's now time to weld together worlds first prospecting shovel.
    I have ordered a suitable collapsible handle that I hope can be a part of my design. It should arrive any day now, so I can go out in the (ice-cold) creek water and try it out.
View project log
