Gold Concentrator Sluicepan
Find gold with the NuggetGrabber
I am a long-time hobbyist gold prospector, now reinventing how to pan for gold by combining a manual goldpan with a sluicebox. Hopefully the design will turn out well and be presented on Kickstarter in order to bring the invention to market.
As an amateur goldpanner and prospector I have travelled to a handful of places all around Europe on the hunt for shiny specks of gold. With gold prices soaring it's a hobby increasing in popularity, and gold can be found almost anywhere in the world. Some gold miners even find nuggets worth thousands of dollars!
Finding gold is often made by a manual process that can be tedious and ineffective, while more serious endeavours require bulky and expensive equipment. That is why I am designing a new type of sluicepan.
1. Floats on the water surface
A regular sluicebox needs to be tethered to the ground, which can be difficult if the water is too deep. By floating the device it can be used almost anywhere.
2. Does not require moving water
A regular sluicebox needs running water, while my invention combines the advantage of a goldpan to manually create flotation and settle the gold.
3. Designed for continuous operation
Unlike a goldpan where paydirt is processed one batch at a time, the sluicepan can be used over and over for hours before emptied and the gold recovered.
4. Easily fits in a backpack
A highbanker or large sluice can be quite big, while the nuggetgrabber will be compact and small to fit inside a backpack. No assembly required.
Read more on my website: nuggetgrabber.com
  • Working on the first prototype
    Daniel Nikolajsen01/07/2025 at 10:52 0 comments
    Nothing beats the feeling when you go from idea to an actual prototype. After extensive research and ideation, it's now time to weld together worlds first prospecting shovel.
    I have ordered a suitable collapsible handle that I hope can be a part of my design. It should arrive any day now, so I can go out in the (ice-cold) creek water and try it out.
View project log
