Introduction
I’ve always been fascinated by Nixie tubes. There is something special in them. Probably their shape, analog feel and the glowing numbers are making these tubes standing out from the new, more modern counterparts. Couple of years ago I bought a couple of IN-14 nixie tubes from AliExpress. To be more precise 3 of them.
It was easy to decide what to use these tubes for: clock. Yes, yet another implementation of a Nixie clock. A bit boring, I know, I know… But, I wanted to implement my own version of it.
As you may know, at least 4 tubes are needed for a clock to show time in format like HH:MM. So, I had two options: order one more tube or come up with something different. Since nixie tubes are not on the cheap side I decided to use only one tube for a clock.
List of requirements
Details
The end product is a stack of 2 PCBs where the bottom one is the control board containing the ESP with Nixie supply and the top one is the display board containing the RGB LED and the Nixie tube.
Operating modes:
In both modes, the configuration page is easily reachable on the following URL: mynixieclock.local. There is no need to keep track of the IP address, the clock is hosting Multicast DNS (mDNS) server. mDNS is supported by Chrome and Safari browsers out of the box.
Short demo:
Note: The demo is without the Wifi tab.
Firmware
This project started on ESP8266 with the Arduino framework, which was great for fast prototyping. However, the reliance on third-party libraries often led to instability and crashes.
To ensure long-term support and stability, the project was migrated from the now-obsolete ESP8266 to the ESP32, using ESP-IDF in C++.
This move provides:
REST API
End pointMethodBody (JSON) Description
/api/v1/led/led_infoGET{
    “R”: <0-255>,
    “G”: <0-255>,
    “B”: <0-255>,
     “state”: <0-2>
Get color and state of
the backlight (RGB LED).
/api/v1/led/led_infoPOST{
    “R”: <0-255>,
     “G”: <0-255>,
     “B”: <0-255>,
     “state”: <0-2>
Set color and state of
/api/v1/clock/time_info
GET{
    "tz_zone": "<Geographic zone>",
    “tz_offset”: “<Proleptic TZ>",
    "time_format": <"12h" | "24h">
Get time zone configuration
/api/v1/clock/time_infoPOST{
Set time zone configuration
/api/v1/clock/sleep_infoGET{
     “sleep_before”: <value>,
     “sleep_after”: <value>
Get sleep mode configuration.
The time before and
after (in minutes)
the backlight will be turned off.
/api/v1/clock/sleep_infoPOST{
      “sleep_before”: <0-23>,
      “sleep_after”: <0-23>
Set sleep mode configuration.
/api/v1/wifi/wifi_infoGET{
    "hostname": "<HOSTNAME>",
    “SSID”: “<Wifi SSID>”,
    "auth_type": <"open" | "wpa2" | "wpa3">,
    “password”: “<base64 encoded password>”
Get wifi configuration.
/api/v1/wifi/wifi_infoPOST{
Set wifi configuration.
Front-end layout & design
Initially, the front end was implemented with jQuery mobile. Reason for choosing this framework was in its simplicity. It provides a simple way to create and control user interface components. One thing that always annoyed me was its low response time. It took too much time to load jQuery, jQueryMobile and theme resources. On top of this, this slow response time caused WDT resets.
One more thing, I just realised that jQuery mobile project is deprecated since October 7, 2021. Huh, when it comes to web related technologies, it looks like I'm living under a rock...
To solve these issues, I opted to completely re implement the frontend using plain HTML, CSS and JavaScript. The end result looks almost the same as the previous design or even better. Responsiveness and stability increased significantly. The only drawback is now in maintenance and extension. It is required to implement everything manually.
Design
Schematic and PCB are designed with KiCAD 8.0
Control board
Control board is basically a re-packaged generic ESP32 board design connected with DS3231 real time clock and NCH8200HV high voltage boost module board.
Display board
Display board uses a CD4028 BCD-to-decimal decoder. Its purpose is to reduce the number of required GPIO pins from 10 to just 4 for showing digits from 0 to 9. Compared to dedicated BCD to decimal decoder nixie drivers (like K511ID1), the CD4028 is a widely spread component and it is available in SMD package. Since CD4028 has a voltage range from 3.0V to 15V it is not compatible with nixie tube’s operating voltage of 170V out of the box. This problem is solved with MMBTA42, a high voltage transistor, rated to more than 200V.
The rest of the display board consists of a WS2812B RGB LED and a pin header used to connect with the control board.
Enclosure design
3D model is made with Autodesk Fusion 360.
The end result is a simple box shaped design with holes for the nixie tube and USB connector.
