Hardware - Control board
A project log for Single Digit Nixie Clock
A small project combining ESP8266 with a vintage Soviet Nixie tube from the 70s to create an artistic clock
daniel-knezevicDaniel Knezevic 5 days ago0 Comments
For proof of concept NodeMCU was connected with a DS3231 RTC module on a breadboard. This was enough to start working the firmware. Later, a PCB was created. The PCB is basically a re-packaged NodeMCU design connected with DS3231 and NCH8200HV high voltage boost module board.
Schematic
PCB
