For proof of concept NodeMCU was connected with a DS3231 RTC module on a breadboard. This was enough to start working the firmware. Later, a PCB was created. The PCB is basically a re-packaged NodeMCU design connected with DS3231 and NCH8200HV high voltage boost module board.
![](https://cdn.hackaday.io/images/original/2047061735919735569.gif)
Schematic
PCB
![](https://cdn.hackaday.io/images/2847431735919821525.jpg)
