emlearn - a scikit-learn for microcontrollers
A project log for Machine Learning on Microcontrollers
Using machine learning to analyze sensor data in embedded systems
jon-nordbyJon Nordby 01/04/2025 at 11:530 Comments
emlearn is an open-source library for implementing. It allows to convert models trained with Python (using scikit-learn or Keras) into portable C99 code.
Here are two presentations that introduce the project. The first is very short and concise, where-as the other is a bit longer and detailed.
