emlearn-micropython - Machine Learning and DSP for MicroPython
A project log for Machine Learning on Microcontrollers
Using machine learning to analyze sensor data in embedded systems
jon-nordbyJon Nordby • 01/04/2025 at 13:17•0 Comments
emlearn-micropython is a Machine Learning and Digital Signal Processing library for MicroPython. It enables MicroPython applications to run efficient Machine Learning models on microcontroller,
without having to touch any C code. It builds on the emlearn C library and exposes a set of small, independent MicroPython modules. The modules (as .mpy files) can be installed at runtime, using the MicroPython package manager "mip". This aims to enable a user experience that is just as convenient and powerful as we already have on standard (C)Python, for microcontrollers.
Here is the first presentation on this library.
