Strob-O-Matic 9000
ESP32 controlled microphone that drives a light to create strobo effects
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
During 2020 the main thing I've learnt, is that if you throw a home-party, you need a Strobo light.
Light effects are extremely important if you want to create an immersive environment, only second to music itself.
So I've created the Strob-O-Matic 9000 which is an ESP32 board that listen the environment through a KY-038 microphone sensor and if the volume exceeeds a certain threshold, turns on a light for few milliseconds though a relay, thus creating the strobo effect.
The threshold is real-time configurable through two -/+ buttons soldered on the board
