4: Final Design
A project log for Analog Sim Handbrake
A sim racing handbrake based mostly around an Ender 3 Pro X Gantry, an Adafruit TLV493D, and a pro micro
cmoon5511cmoon5511 01/13/2025 at 21:150 Comments
The design is nearly finished, any last changes will probably be done once the initial print is put together. I am hoping to reuse some of the threaded holes on the extrusion for mounting the return spring. If that doesn't work I will have to come up with some sort of solution which shouldn't be too hard.
I need to wire up the components and start working on the code. Hopefully I can steal from other people's code used for similar projects I have made.
