I did not do the things I set out to in the last log. I found a good spring inside a cheap spring loaded desoldering pump I had kicking around. I added some foam backer to the plunger stop to act as a sort of damper. Some of the holes I left for heat set inserts are too close to edges to be usable. I will try getting this programmed before I start printing the final batch of parts. I also think I could make the grip a little bit wider.
