Desktop device that outputs a variable voltage whose value is controlled by the user.
Apparently, "Calling HAL_ADC_Stop(&hadc1) after the entire for loop ensures that before the $100ms delay and the start of the next while(1) cycle, the ADC peripheral is completely reset and put into a clean IDLE state. This allows the very first HAL_ADC_Start() of the new cycle (for $i=0$) to initialize the sequence correctly and produce valid oversampled data again."
Hulk
Sagar 001
icstation
Daniel
