Working on a light and sound module for a RC truck which communicates with "child boards" using I2C interface at some point I needed a I2C USB interface to be able to test the slave boards after assembly. I2C-Tiny-USB is perfectly suitable for this task because it works out of the box on linux. Instead of assembling another board suggested by I2C-Tiny-USB project I found in the toolbox one of the USBasp programmers I've ordered long time ago. So the fork was born.
The result of the modification can be found here: https://github.com/Gamadril/I2C-Tiny-USBasp
A quick test with a connected ssd1306 based 0.91 oled display showed that it just works...
gamadril.dev
Lacho Tomov
Alex
Sven Gregori
