I built a single module to test the concept. The module was driven by a geared 15mm stepper motor which was controlled by a cnc shield. I quickly realized that the torque need to turn the cams and followers was much more than I anticipated. The 15mm motor ran very hot and overworked. So in the next iteration I used 20mm geared stepper motors
